just came back from the dealership. they put the 'stique on the diag and found that i need a bank #1 & #2 sensor replaced at $136/each, 1.5 hr labour for bank #1, and 1 hr for bank #2. they also said that the IMRC was stuck closed and will eventually need to be replaced, at a cost of $450/500.
do these sound like reasonable prices, or am i getting fleeced? does anyone have any alternatives that i can look at?
benji
Assuming that you are referring to the 02 sensors, that is about what they cost, each, but I have seen them for under $120.00 each. The IMRC, hmmm, last time I checked, it was somewhere in the $300 range for the part, and should only take 45 minutes to change out. $500.00 seems pretty steep.
I would verify the functionality of the IMRC. If it is stuck closed you would have no power above 3000 RPM. If it is not working check the cable to make sure it is still attached to the LIM.
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
When My IMRC went out on me, The Cable was frayed at the end where it went into the IMRC box. I didn't feel like getting a new one so I removed the butterfly valve off the LIM. In other words no secondary's (sp?). I've seen dyno plots proving you get a 1 or two HP on top end. Also you can do the work yourself. It's not hard to do. You could also get the IMRC somewhere other then the dealership and put it on your self.
ED Black E0, 3L Hybrid. Long time ago... It was fast. real fast...
IMRC
Meadowvale Ford (Mississauga): $249.84
Discovery Ford (Burlington): $237.94
I called both places last week as my IMRC cable is FUBAR. Go figure. (It's not difficult to replace if you have some dexterity.)
1999 Red / Tan SVT #1969 of 2760 Built 4/21/99 K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links 17" FSVT 5-Spokes Factory Spoiler 35% Tint All Around
If anyone is in need of an IMRC, I have one that I'll let go.
PM me with an offer. I am in HAmilton BTW...
-j.
96 LX 3.0L MTX - Black/Tan K&N; 12lb F/W & uprated clutch 2.5" Pipe; SVT bits; Mystery Mod; Pull-tie Mod; UN-tuned Mod; 3rd Gear Synro-Crunch Mod 280K on the Shell, and 40ish on the Motor... 1/4 mile?? Yeah, it's a fun daily driver...
thanks for the help guys. just got some money to get everything fixed on my ride, so i will be checking out those dealerships. chris, you can expect a phone call real soon.
benji
Moderated by  Gerald_dup1, mbb41_dup1
