#745990 09/12/03 11:08 PM
I don't know where the proper place to post this at is, but I saw the bad clutch post and figured what the hell. I got my clutch replaced last february and now I am experiencing slipping. 3rd gear test failed.. revving high without speed keeping up sort of things. I was told that it could be my slave cylinder that is going because my clutch is so new. So my question is what are the effects of a bad slave cylinder and if anyone has gotten this work done at a shop/dealer/ or otherwise, what kind of price am I looking at if it is indeed that.
Thank you
Kevin
Black 98.5 SVT "Kellie" First rule of italian driving: What is behind you, DOESN'T matter
#745991 09/13/03 01:36 AM
A bad slave will usually leak down and re-engage.
Did you have the flywheel resurfaced?
Early slippage other than from abuse is normally from mis-adjustment. A lack of freeplay will keep the fork from fully disengaging, allowing slippage and wearing out the throwout bearing. If the clutch pedal seemed too high since the clutch was installed, it was probably mis-adjusted.
The only way the slave cylinder could cause this is if it was sticking. I'm sure you would feel this in the pedal.
#745992 09/13/03 07:13 AM
TGO Offline
and, they should have installed a new slave cylinder with the new clutch...
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
#745993 09/13/03 07:55 AM
yeh well.. I am pretty sure they didn't.. that being just one of the plethora of things they [censored] UP!!! on my car
#745994 09/13/03 06:33 PM
For $90 extra it's a great thing to change when the trans is out of the car. IIRC, most clutch kits have the slave cylinder. Do you have a leak from the bottom of the bellhousing? Do you have any issues with the pedal not keeping pressure, where you may have to pump it to allow the trans to shift into the next gear?
I know when my slave cylinder was bad, I had to double, triple or quadruple clutch that filthy whore to get it past 2nd I knew my slave cylinder was way bad off!
2005 Ford F150 SuperCab FX4 1964 Chevrolet Impala SS 1998 CSVT: 354HP/328TQ @ 10 psi, now gone
#745995 09/13/03 06:36 PM
It sounds like you're talking about cable operated clutches. IIRC, you might be able to adjust the pedal's engagment points....but that's about it for a hydraulic clutch.
#745996 09/13/03 08:09 PM
Have you tried to bleed the clutch yet?
2001 Lincoln LS8 1994 Lexus GS300
#745997 09/14/03 12:04 AM
this week I want to bleed the brake lines and the clutch.. hopefully that helps out a litte. I am just deathly afraid of another 1300 dollar bill.
#745998 09/14/03 12:31 AM
Is there a proceedure for the clutch bleed I can do myself.. is it just like the brakes.. or should I take it someplace.
#745999 09/14/03 02:56 PM
Fourth post down
I need to do that this week, too. I was having some serious issues w/ getting my car in (any) gear yesterday.
Funny thing is, as soon as I turn the car of, the shifter will slip right into gear.
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
