Depends on how the trans is lubricated. If the lube is splashed/pumped from the "input side" of the tranny, then NO, don't tow it with the drive shaft turning the remainder of the tranny. You won't have any lube pumping or splashing around.
The safest solution is to either put the whole car on a trailer or disconnect the drive shaft.
TB
