Posts: 334 |
here's the scenario...
1. im at a red light... turns green.. i floor it.. car goes fine.. 1st 2nd 3rd.. so on.
2. im at a red light... turns green.. i floor it.. and make a right hand turn/or left secondaries open at 3,500. car hit 5,000 starts bucking like a wild horse and the rpms won't climb. then i let off the gas and regas and everything is back to normal. does it everytime. started 2 days ago... any advice??
Posts: 352 |
Yeah, sounds exactly like a clogged fuel pump. Here's why. Returnless Fuel Pump Exposed! ...Ed
2000 Silver Frost SVT #1625 14 Jan 2000 Dual Mode Dampener A/C switched K&N Dropin Magnecor
Posts: 334 |
Those pics are from under the rear seat?
Posts: 3,950 |
Originally posted by breidy: Those pics are from under the rear seat? Yes they are.
Posts: 334 |
So am I cleaning the filter or replacing that pos? or should i try that fuel additive to see if it cleans it? I only have 27,000 miles.
Posts: 1,040 |
Since you car appears to be still under warranty have it checked by dealer.
Posts: 334 |
well it's at the dealer now... getting the fuel filter replaced. $50 /w labor. and i went ahead and told'em to change plugs too.
lets see what happens. :rolleyes:
Posts: 334 |
fuel filter replaced $50 /w labor.
done deal. issue fixed.
Posts: 2,848 |
Too bad im too late...same thing was happening to me, car was bugging out at high rpm, I thought i was just hitting the fuel shutoff as it was usually when racing. One day, started bucking like mad around 4k rpm, then a few blocks later at around 2500, then anything above idle...then I was on the side of the road waiting for a tow truck lol!
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 352 |
Hi, Something is escaping me here. If your regular fuel filter attached to the side of the tank was "clogged" and was causing fuel starvation or flow issues...what then do the THREE filters inside the tank look like??? You show you have a 2K SVT which has a returnless system and the additional "filter disc" on the bottom of the sump. Having had these filters in my hand, I am in disbelief that enough dirt could have gotten past this primary filter disc, past the secondary filter sock on the pump itself and, past the tiny "injector" style" filter insert in the end of the pump discharge tube to sufficiently clog the external filter to cause a problem!!!! There must be some other "mysterious force" at work here! Help anyone??? ...Ed
