Posts: 83 |
Ok, my O2 sensor went bad, well, apparently. My CEL ligh came on, so I took it to auto zone, they said it was the bank 2 sensor. So I bought the replacement sensor, but I can't find out where the heck to put it!? Yes I did try a search.  Also, it seems the car is running fine, i've put quite a few miles on it since this has happened. Could this be a glitch?
98 E0 #848 KKM Rear SVT emblem (Thanks nyceboi!) .. more to come
Posts: 1,040 |
Did you reset PCM after code read? What was exact code, since there are 4 sensors, 2 in each bank.
BTW a search as follows returns 45 hits: O2 sensor>Problems>Subject Only>Any Date
Posts: 168 |
Buch, you're in luck. Bank 2 is the front bank, which is much easier to get at than bank 1. Now you just need to figure out if it's the top or bottom sensor that needs replacement. The OBDII scanner would tell you this. So I bought the replacement sensor, but I can't find out where the heck to put it!? Here's a hint: it goes on the front exhaust manifold, near the oil filter. There are 2 sensors there, one on either side of the cat.
-Kurt
"I'm a little sceptical of that internet thing. After all, what's it got besides information?" -DB, 1/97
Posts: 83 |
and the code should tell me which of the two to replace?
Posts: 1,040 |
Posts: 83 |
Administrator
Administrator
Posts: 702 |
Originally posted by buchsvt: P0430 What side? P0430 - Catalyst System Efficiency below Limit - Bank No 2. That means the sensor after the cat in the front bank is showing insufficient change in O2 levels from the sensor above the cat. It could be mean either or both are bad. It could also mean that the connections on the lower one are loose. -Lance
Lance Kinley CEG Webmaster 95SE, "Official CEG Beater" Quaife, SVT parts, ST200 wheels, SS Y-pipe I perceive you to be a stand-up, rational individual...
Posts: 83 |
So I just check the connections, replace one of them (if needed) and if the CEL doesn't go off, replace the other one?
