I feel Guilty, Oh so guilty
Posts: 4,789 |
Originally posted by bullion: I beg to differ. I tried running my setup with and without the amp and right now I am still using the factory amp.........sounds pretty good. Here is what I did. I turned the "Loud" setting off on my deck (kenwood mpv-619), I set the "V-Off" to about -2 or -3. Plus, I am running bass blockers on both the front and rear set of speakers. I think you get better sound this way (better bass too).
You will actually get higher distortion levels because you are compounding the distortion from the deck with the relatively high levels in the factory amp. I trust that you like the sound better, but based on every (100% until yours) review I have ever seen, bypassing the factory amp results in better sound.
-Mitch Hedberg
Posts: 147 |
Listening to speakers in a constructed sound display unit versus listening to the same speakers in your vehicle will not yield the same results.
You have deflections, cancellations, interior conflicts, absorption, etc. to deal with in a car environment that you may not experience in a controlled sound room. I'm sure the speakers you were listening to where closer to ear level as well. Were they on axis? More than likely the speakers were installed in enclosures as well.
The same situation applies to consumers that listen to home audio in a controlled listening room and love what they here until they bring the same package home and realize it doesn't sound the same in their home. It's a matter of fact.
Your head unit is not putting out 45 watts R.M.S. If you're looking for that kind of power output, get yourself an amplifier. You won't be disappointed.
1998 Contour SVT
H&R, Koni's, 17" Team Dynamics DTM
Upgraded Stereo System
Posts: 3,264 |
Did you just say you prefer the factory amp? I need your address so I can go over there and beat you with a mallet
Posts: 1,359 |
LOL. It is just something to get me by until I can buy an amp. And yes, you are correct in saying the distortion levels would be higher when I run my deck to the factory amp.....I just like the fuller sound it gives me. Which, by the way......what would you recomend as far as a 4-channel amp goes to power 6.5" speakers (in the front) and 6x8" (in the back)? I don't want to spend a ton of cash, but don't want crap either.
98' Contour SVT
#607 of 6535
05' Mazda 6s
Audio/Visual enthusiast because it's one of the many things I went through 4 years of hell for
Posts: 569 |
Originally posted by bullion: LOL. It is just something to get me by until I can buy an amp. And yes, you are correct in saying the distortion levels would be higher when I run my deck to the factory amp.....I just like the fuller sound it gives me. Which, by the way......what would you recomend as far as a 4-channel amp goes to power 6.5" speakers (in the front) and 6x8" (in the back)? I don't want to spend a ton of cash, but don't want crap either.
Hay check out www.cardiscountstereos.com That is where I ordered my 10in HED series cerwin-vega. They have some good prices.
....Brad
Your mom thinks I'm hot!! But my wife rocks!!
99 Mestique Zetec ATX, 96 4Runner 5speed
Mods? Um gotem.
VFA-94VFA-122 VFA-115
Posts: 1,359 |
Thanks, I'll check it out. I have a hard time paying above cost on electronics after working at Best Buy for 3 years. I got everything at cost and when you are talking about car audio equipment, you can expect to save about 50% off the retail price tag.
98' Contour SVT
#607 of 6535
05' Mazda 6s
Posts: 460 |
thanx for the replies guys... i checked my setup... which my dad btw put in a while back... the amp is by passed and my problem came from the fact that i used only 3 outa 6 mounting holes on the speakers... made a HUGE difference.
Lexus ES300
