i was wonder does it affect the normal operation of the excelerator causing a jerking motion and the tranny slamming????? i wondering does it have anything to do with compression of fuel is being block . but engine does not stall//need help
robert atkinson
A dirty fuel filter would not cause your tranny to slam. Some signs of a dirty filter are rough idle at startup, poor fuel pressure and stalling. Sounds like you have some issues with your tranny. Try changing your fluid and inspect it for pieces of metal. Small pieces are normal but larger pieces are not. You may want to take it to a mechanic if you are not comfortable with this.
99 CSVT Green/Tan 13,700Km
# 84 of 2760
For Sale
96 Contour GL 2.5 ATX 120,000Km
K&N Air Filter
Mobile 1
E1 SVT Wheels & BFG G-Force Rubber
Aluminum Painted Front Grill
Replace the fuel filter every 30k.
Fuel Filter should be replaced every 15,000 - 20,000 miles.
If you wait for every 30,000 miles to replace it,
you'll be replacing the fuel pump with it, at 60,000 miles.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Just regurgitating the Haynes recommendation.
I hate to admit this, but my OEM fuel filter outlasted my first engine. 88k miles on it; still on the original (returnable) fuel pump.
H
H
Originally posted by RoadRunner:
[b]Replace the fuel filter every 30k.
you'll be replacing the fuel pump with it, at 60,000 miles.[/b]
Strange, the service guide for my '98 makes no mention of changing fuel filter, but it only covers service intervals up to 120,000 miles (200k km). Maybe they give you a new guide when you get to that mileage. smile
p.s. Cabin air filter should be changed every 20,000 miles.
stock CD on LS, cass on LX
4 wheel discs on LX only
I change mine every year (10-12k)
Cheap and easy insurance. Maybe a 5 minute job & $7-8
Get a Purolator/Motorcraft & make sure the clips are in the box.
2000 SVT #674 - Check it out!
uh, my niece's '89 Beretta (which used to be mine) has 185,000 miles on the original fuel filter...we HAVE changed the oil occasionally, though.
2000 Contour SE Sport T-Red MTX, Mystique rear dome light, Blau Florida cd.
would this make your car sound any different? i hear a putting when i turn my car on...a loud putt...lack of power...and the exhaust smells a little....if this is the fuel pump/filter let me know cause im taking apart my exhaust tomorrow to check out my cats (which were replaced under cat warranty at like 55k) i am now at 83k thanks
Golof, you might have a clogged main cat. That will suck up the horsepower like nobody's business.
'98 SVT
KKM / TH fix / Mobil 1 / Synth tranny cocktail / JVC LX-30 HU / 10" JL sub / Alpine V12 amp / Panther 199 wheels / Kuhmo Ecsta 215/45/17 / Bosch +4 / Ford Motorsport wires
