Posts: 332 |
if i add a switch, the one with only two prongs, not the three prong ones, do i still need to add a fuse. Also what is the main difference between a two or three prong switch?
Posts: 222 |
What are you trying to switch?
A Single-pole, Single-throw (SPST) switch has two contacts. It would typically be installed in series on the hot (powered) side of the circuit- which is usually fused. You cut the hot lead and connect the switch. The switch then simply completes or interrupts the circuit.
A Single-pole, Double-throw (SPDT) switch will have three contacts. The hot would go to the center connection and the two items to be switched would go on the others. In this case when the switch will complete one ciruit or the other depending on which way it is thrown.
The there's the Double-pole, Double-throw (DPDT)switch that has 6 terminals, and auxiliary relays for switching higher current items....and on and on.
Give us a bit more info.
AL
Red '98 SVT E0 3098/6535
DMD
other stuff
and a Bullitt fuel door
Posts: 4,639 |
i'm in the process of adding leds and switches to my car. the 2 prong r generally on-off. the 3 prong or on-off-on where one on can be used as a momentary type setup. or the 3 prong ones use the third for a built in led.
what do u have in mind.
Hugo AIM:omegazodiac
Posts: 29 |
go with the 3 prong with the built in led. the top prong=ground middle prong=12vpower bottom=accesory,which is basically for the led just tap into your wires for the cig. lighter
black 98 svt
power 1 mufflers w/resonator removed
jvc headunit
rear reflector and front grille painted black
ding guards removed
side badges replaced w/apc oval lights
born on sept. 3rd of 97' #3,382 of 6,535
Posts: 332 |
Originally posted by svt contour 98: just tap into your wires for the cig. lighter
it seems there are a few wires back there. could you go into a little bit more detail.
sorry i am a new-b on this electrical stuff
Posts: 800 |
Originally posted by svt contour 98: go with the 3 prong with the built in led. the top prong=ground middle prong=12vpower bottom=accesory,which is basically for the led just tap into your wires for the cig. lighter
I have that switch. I put it in for my antenna, so I basically have my remote-turn-on coming from my head unit to the switch, and from the switch to the power antenna. I am using the top and middle prong. So if I wanted the led inside the switch to light up, should I just get the 12v wire coming straight up from the cig lighter? Is it too much power, or is it alright to put in 12v for the accessory?
