It's August in Ohio, which means it's warm out. I am having a bit of a problem. After I engage the e-brake, and release it, the driver side won't release. After about a mile or two down the road, it will release. Once it didn't release at all, and I had to use a brass hammer to tap the lever on the caliper back to it's original position. Is this a faulty caliper like I am assuming, despite the idea of 57k miles? Is there anything I can do, such as rebuilding the caliper to fix the problem, or is replacement the only option? It's a 2000 CSVT.
