its been catching my attention...doesnt matter what the temperature is outside...ill turn her on and it will rise over half way...then slowly make its way to the red area.
should i flush out the radiator fluid and replace it? or should i just add water??
Teal|'95 'Tour GL|75k| 16V 2.0|Rebuilt ATX|
Factory Euro Mod's (Ordered in Dec '94 From Holland)-|Larger Radiator, Oil pan, Fan, Tank..little things make a difference|
Mods to Come-|Open air w/K&N filter|New Exhaust|Pre-98 Bumper|Trim Kit|Fox 2 Rims|& More..|
You should probably check connection at sender unit on engine. It could also be the sender unit. It is definitely not a coolant problem.
Same thing happened to my Zetec, scared the shizzle out of me. The temp sending unit for me was only about $23, and it's pretty easy to get at (On a Zetec, that is )
PM me if you need instructions on how to change it out, I'd be glad to help!
I have always heard Zetecs run high sometimes but all the way up to the red... Damn B That takes the cake...
John 1996 Ford Contour Zetec. ~Torreador Red 5 Speed. ~17" Nocturno Rims w/205-40 series tires ~SVT Shift Knob Thanks to Eric ~Custom painted cowl, wipers, mirrors, sail panels ~Color Shifting interior highlights ~Eibach Lowering Springs. ~Pioneer C.D.Player. ~5% Tint on all windows including front window. ~Custom Black Dyed Carpet. ~Fubo Antenna In Middle of roof. ~Shortened Billet Antenna in rear. ~Indiglo BNM Gauges and ~Speedpeople Indiglo HVAC panel. ~High Flow Cat. ~Custom exhaust. ~Custom dyed Steering wheel. **Soon to come** ****Air Cylinders**** **Another TV/DVD Player ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
