Posts: 34 |
I have a hard shift from 1st to 2nd gear when I back off the throttle quickly at high rpms. My car is an automatic has 90k miles. I heard that a lot of contours do this.
My question is do they all do this from the beginning when the ATX is new? Does this damage the transmission? Thanks for you replies.
'96 Mystique GS 2.0L ATX
Posts: 1,145 |
dont know if it damages it but yeah i think they do that when they are new because when my transmission was replaced it did the samething you are describing and other wise the transmission shifts fine
98.5 Black SE ATX
Posts: 21,653 |
As hard as the bang shift is, it's hard to believe that it can't damage the tranny. When I got my chip, it helped out a lot. Also a lotta people have had good result by replacing the TSS with the newest one. Though others have had problems with it.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 1,603 |
Tom, There is a new Turbine Speed Sensor that cures this. There is plenty of info in this thread... 1-2"BANG" Shift is GONE !!..
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 635 |
I'm going to have to try this, even though in 2000 I made the dealer do TSB 98-13-11 involved a re-program (FTPT 12a650-dpa) and swapped the servo for one with a stiffer spring. Anyhow it still gets confused but not with force it once did. Who found this out?????? THANKS!!!!!!! Chris????? Tnx Paul 98 Mystique LS (built 07/97)
Paul
98 Mystique LS 2ea (07/97)(08/98)
Posts: 635 |
Anyone else that had the TSB done, try the new TSS? Tnx Paul
Paul
Posts: 1,044 |
I replaced the TSS on my 95 and it has improved the 'bang shift'. The sensor fit correctly on my 95 which did not have the yellow paint markings described in some of the forum discussions. This is about a 15-20 minute job.
Posts: 34 |
Originally posted by Kremithefrog: As hard as the bang shift is, it's hard to believe that it can't damage the tranny. When I got my chip, it helped out a lot. Also a lotta people have had good result by replacing the TSS with the newest one. Though others have had problems with it.
Kermit I have a 96 atx also. Did you eventually change your sensor to the new one mentioned in the article? Did it help?
Posts: 4,220 |
I replaced my TSS. It greatly helped the problem, but it did not alleviate it totally. It's more of a small bump now than the incredible jarring that it used to be.
2003 Mazda6s 3.0L MTX
Webpage
2004 Mazda3s 2.3L ATX
Posts: 7,117 |
Replaced the TSS in my '99 V-6. The difference was huge. Much better behaved tranny all around. I also have a Superchip that gives me slightly firmer shifts at higher RPMs than normal - it helped too.
