Posts: 79 |
Anybody knows where that is? I get this really moisty air comming in when I turn my ac off. i suspect that plug may be clogged or smth. Thanx for your help!
Andrei. 98.5 Contour Sport SE,V6,MTX beeeph.
Posts: 229 |
You may need to replace your passanger cabin air filter.
99 CSVT Green/Tan 13,700Km # 84 of 2760
For Sale 96 Contour GL 2.5 ATX 120,000Km K&N Air Filter Mobile 1 E1 SVT Wheels & BFG G-Force Rubber Aluminum Painted Front Grill
Posts: 1,861 |
The drain hole is a little hard to find. It is on the firewall and on my car it is directly above the front of the main cat. It does not have a "duckbill" flap like many cars, instead it is just a hole through the firewall into the A/C plenum. If it is plugged, you should be able to clear it with a bent coat hanger.
As Rob Shaw posted, it is very likely that your cabin filter is dirty. If you have not changed in the last 12 months, you should. That can be the source of your odor. Thaere is a great FAQ on how to change it.
Jim Johnson 98 SVT
Posts: 79 |
sorry to bring this up again, but i've tried like 3 times to find that hole  ( JUST TO BE CLEAR: the water drain hole....)and no results... Anybody has a picture of that? Thanx
Posts: 5,805 |
Follow the heater hoses to the firewall, the hole is about 1" below them in the center...can only 'see' it with the engine out....
Posts: 79 |
thanx Terry, i think i know where to drill...
