Has anyone had engine problems that resulted from the timing chains on the 1995 V-6 loosening?
I know there is a tech bulletin from Ford to replace the chain tensioners with newer ones to deal with engine noise on start up, but has anyone had additional problems?
I now have several bent valves, one broken one, and a hole in one piston because the timing chain slacked off and jumped, just wondering if I'm alone on this one.
