Posts: 98 |
Hello everybody i need some info on what is the best tire size to run? i am thinking about getting some 17" rims for my car. Right now a have 14" on it it is a contour gl. what ones will not have a rubing problem? and have some good size side wall high to protect the rim? i live in ITHACA NY. the roads are not that great.
Posts: 837 |
If the roads aren't that great you could go with 225/45/17's and give yourself some extra sidewall and traction. But the thing is you might rub depending on the offset of your rims. If you get 215/45/17 you won't rub, but the ride will be harsher. Also given what I've seen on a lot of tire websites 225/45/17's are usually cheaper then 215/45/17's (see Tire Rack ) Good Luck!! Bridge
CSVT
Feels Like Heaven
Goes Like Hell
Profile
Posts: 98 |
Thanks, i did look on the tirerack web and there are some rims on there that i like they are the Mille Miglia MM11-3. they are a new style. they recommend 205/45/17. but dont know the side wall high.My buddy at goodyear can get them for $155 instead of $189. Ceck them out. i think they look good.
Posts: 4,639 |
dont do 205/45/17. stick to 215/45/17. its the closest to overall stock diameter. 95% should agree.
Hugo AIM:omegazodiac
Posts: 1,085 |
Originally posted by hmouta: dont do 205/45/17. stick to 215/45/17. its the closest to overall stock diameter. 95% should agree.
I'LL second that....
2012 Lotus Evora
95 Mystique MTX - GONE 395,000 Kms
--------- Both Zetecs
'97 Contour Mtx - stock - GONE
Posts: 2,517 |
Originally posted by WestCoastAjax: Originally posted by hmouta: dont do 205/45/17. stick to 215/45/17. its the closest to overall stock diameter. 95% should agree.
Thirds.
Posts: 98 |
THANKS you guys what about 205/50/17 the guy at goodyear said to run those is he wrong? is that not right. Well with all of you telling me to go with that size i most likely do it since you all no about that tire size and that it works.
Posts: 1,603 |
I'll Fourth that.
I got a set of 215/45/ZR17 tires and they are just 0.04mm SMALLER
than the stock FireRocks that came on the Contour...
You can't get any closer than this size !!!
205 will be a narrower tire, and the 45 will make the
sidewall/tire diameter smaller.
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 98 |
THANKS' made my disc it will be 215/45/17. thanks for helping me out. Now all i have to do is choose the rims i want. Looking at the Mille Miglia MM11-3 from the tirerack. In bright silver paint. Or the ff5 in silver. check them out and let me now what you guys think.THANKS again
Posts: 4,639 |
yeah 205/50/17 is even worse.
