OK, so my passanger front wheel will move left and right about 1/2 an inch or so when the wheel is off the ground and the drivers side is on the ground ... anyone know what I can check or fix to fix this? This makes it so that my car drifts left and right when I brake and press on the gas. Its wierd I know. Any help is gladly appreciated.
Thanks
Jared
http://svtitan.com 98.5 Black SVT #6364 6/9/98, Xenons, 18' Neeper Titans, KKM, (4) 15 Kickr L7's, (2)Ethqwk PHD2's, Memphis 3004&st150,(4) kickr 6.5 subs, ID CD2 Horns, 5%, Bassani, GC, Koni's, B&M, 153.4dbDBDrag
Get some light under there and inspect the tie-rod ends. These swivel joints wear and movement between sides requires their replacement. They are quite cheap to do yourself so do all four if you have time so only one front end alignment is necessary.
possibly wheel bearing.
Definitely the tie rod ends. I failed inspection in the 'tour due to those being bad, and the symptoms were precisely the same.
GREAT SCOTT !
I certainly hope he didn't let a wheel bearing get that bad!
Yea, could possibly be a wheelbearing as a result to it too, just recently my wheel bearing on my drivers wheel was completly destroyed(I could move my wheel 5 inches inward ), due to a pothole in the road, i thought my car broke! ahh. Anyways got it repaired quickly so no real damage happened phew! Get it fixed quickly!
Contour is SOLD 97 GST eclipse is SOLD 2002 S2K...
b0x @dm1n
b0x @dm1n
Ball joint or tie rod end!
-Andy
Andy W. The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
