#738391 09/04/03 03:53 PM
JD60538 Offline OP
Yeah, I know, this has been asked many times before. Sorry!
But, I bought my car auto so my wife could drive to(one vehicle), I'm buying her something else and want to put an MTX in mine. I know its possible. My q's are:
are the electronics the same or close enough? Sensors, ETC.
What upgrades should be done to the trans before it goes in?
Thanxz
1998 Contour GL Zetec I4 w/auto MODS: Fog lights and Mesh grills Soon to come are a set of Rims and Yokohama AVS ES100's Come see at cardomain.com
#738392 09/04/03 05:06 PM
H
H
I found this list of parts needed using the search function. This list was taken from someone in NECO who did the swap. In addition to this, you will need an ECU from an MTX 'tour. If you want to "upgrade" the tranny, you can always send it to Terry Haines who can install a new differential (Quaife LSD would be my personal choice) and change out the synchros, spider gears, etc. I'm not sure what the cost would be, I've been told around $1300 for the treatment, but that was not from Terry himself.
MTX75 Transmission $1600?new $~700used
Clutch Disc $100.21 Plate $103.20 F7RZ-7550-AA & F7RZ-7563-AA
Clutch Slave cylinder $73.84
Flywheel $94.48
Left half shaft $150?
Right jack shaft $50?
Clutch Master Cylinder $29.19
Clutch Pedal Assembly $178.62 F7RZ-2455-AA
Clutch Hydraulic line upper $15
Clutch Hydraulic line lower $15
Clutch fluid supply line $5
Mount-fender side $85.22
Mount-tranny side-left $41.25
Mount-tranny side-right $40
Mount-cross member side-right $36.97
Shift Tower Assembly $72.97 XS8Z-7210-BB
Shift boot $29 regular $99 leather
Bolts- Clutch to flywheel $2
Friction Modifier $3.60 XL-3
Crossmember $450
Shift cables $45
3 quarts Mobil 1 synthetic ATF $15
Vehicle Speed Sensor-mtx $50
134Kohm resistor $1 Radio Shack
Here is the thread it came from.
#738393 09/04/03 06:19 PM
bingo! my upgrade from terry cost $1270 so thats right on par. luckily all of my syncros were in great shape and didnt have to be replaced. the two big things i got were a quaife and the zetec final drive.
#738394 09/04/03 07:09 PM
H
H
Actually I think I got the $1300 from you indirectly. I was talking to James (svtcarboy) at the national meet about me driving over to Terry's and having some preventative-type work done, and he mentioned your work cost $1300 from Terry. What was the full list of work you had done, if I may ask?
#738395 09/05/03 05:31 AM
I would LOVE to have an MTX in my 'Tour, but if I'm looking at all that expense, I would hesitate. Then I would think about all the work.
Solution:
I'd sell my ATX Zetec & buy an MTX Duratec.
#738396 09/06/03 06:11 AM
Quaife diff assy 491.00
2 x diff bearings 35.16
2 x drive shaft seals 14.20
shaft bearing 27.83
shaft bearing 38.23
1/2 shift fork 15.70
3/4 shift fork 24.98
speedo gear 6.30
seal assy shift shaft 33.83
Zetec output gear and shaft assy 112.27
Zetec final drive ring gear 45.87
Total parts 845.37
MI tax 50.72
Labor 375.00
Subtotal 1271.00
