Posts: 5 |
Does anyone know where the VSS is located. My speedometer and odometer don't work. They are electrical and I am having trouble locating the connection. I just replaced my bank 1 O2 sensor and I think I must have loosened the connector. After O2 replacement speedo stopped working. I have seen several posts saying you can find it by following the cable, but I don't have a cable. My haynes manual doesn't talk much about the VSS.
Can anyone help me?
Thanks!!
95' Contour V-6 MTX No Mods, 136,000 miles And I can still beat my friends '99 Eclipse GS ;-)
Posts: 5,805 |
On the transmission case,above the area of the diff,near where the drive shafts go in...
Posts: 5 |
I feel like a real idiot. Is it easy to spot? I see a connector just below the left side of the exhaust manifold, but it looks like it goes into the block not the tranny case, but it is close. I see no wires or connectors around where the axles go in the tranny. I have a 95 v-6 with a MTX if that helps any.
Thanks for your help.
Posts: 5,296 |
Follow the speedometer cable all the way down to the transaxle casing, the VSS sits right there.
Posts: 5 |
Thanks for the reply, but I have an electronic speedo. I wish it was that easy.
Thanks!!
Posts: 5 |
I found it!! Thanks everyone. The mistake I made was, I was looking for a wiring harness coming out of the tranny's side. What I found was a black box with no wires coming out of it and 3 wires dangling loose. That's right, the wires had been ripped out of the VSS. So, I will be working on replacing that. This would explain why my speedo doesn't work.
If any of you have any recommendations on replacing the VSS, please let me know.
Thanks a lot!!!
Posts: 5,296 |
I didn't know any '95 comes with electrical speedo... Anyway, just buy a new one and put it on.
