beemu Offline OP
'99 2.0L Contour with 40k miles. If when the car is accelerating in 1st gear and I suddenly take my foot off the gas (as would be the case when going a short distance between stops) the tansmission will noticably "bang, slam, etc" into 2nd. The car has done this since I bought it used at 32K. Most of the time I can avoid this by acelerating more slowly or by letting the car go into second before taking my foot off the gas. A drain and refill (2x) of the ATF did not make a difference. I also noticed this same behavior in another '99 2.0L Countour I test drove before buying this one.
Is the CD4E just not a smooth shifter or should I be worried about this? Thanks!
Just don't take your foot of the gas. It's normal for our cars. A chip and/or performance transmission kit would probably fix it. Though some cases get worse than others and require attention. I'm sure your car is fine though.
"Wow, that sank fast." "Yeah, like a rock."
96 Contour GL ATX
9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned
Sony CD player: 50wattsx4;remote;
Speakers=50 watt Pioneer 6x8s
Ross Evans smile
beemu Offline OP
Redcon- Thanks for the reply. When you say a chip do you any of the performance chips or is there one that specifically addresses this program? From what I'm gathering this behavior is not a mechnaical problem but the PCM "telling the transmission to slam into second" under certain conditions.
I also found this thread:
http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=3;t=007701
Some claim resetting the PCM can help. I might give that a try today wink
My V6 SE ATX did this too. Just don't abruptly take your foot off the gas.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
