I have a 98 Mystique, I lowered it using the Eibach lowering springs. I then replaced the factory rims and tires with 16" fast rims and Potenza 225/50r16 tires. Now I get wheel rub when I corner fast or hit a bump. I got the fenders rolled which reduced it alot. So my question is should i go down a tire size in the rear(if so what size should I use). Or should I buy a new set of struts(if so what kind).
