#736876 09/02/03 10:05 PM
I have a deal on a 75mm Pro-Flow...$100 delivered. It is programed for the same mods as I have, is it worth it? I am also looking into MSDS headers and y-pipe so it will probably need to be reprogramed. What is the cost to get it reprogramed? Or can all be corrected with a chip?
Thanks,
Scott
Scott 2000 Contour SVT #1464 Mustang Dyno: 171.6hp/145.3lb Dynojet Dyno: 171.1hp/148.9lb 1989 20th Anniversary Turbo T/A "Indy 500 Pace Car" #1376 of 1550 All Original, 46k with a few mods 2002 F150 SuperCrew
W
W
You really can't program a MAF to your mods, you can only program it to richen or lean-out the air-fuel ratio. If it is tailored for 19# injectors then its probably OK and probably a good deal. The headers really aren't that relevant when it comes to the MAF and its calibration.
O
O
some are happy with pro-flow but mine $uck
New Pics of OUTKAST 1!Sept2006
I dont see you needing it with the mods you have listed. I doubt you would see that much of a gain, if any.
"...first he's gonna s*!t, then he's gonna kill us." 1999 Contour SVT Retrojunk.com
F
F
I'd get it, and at that price its to hard to pass up.. It will improve performance once you keep modding..and modding for power.
I just bought one for $125 and it works well.. apexi and pro flow...yummy...
eric
I was very pleased with my Pro-Flow
But as for re-programing, Pro-M will charge you $100 for every re-burn you do.
RamMotorsports Lowest prices on SPEC Clutches and Flywheels
W
W
Thats why you pair it up with an SAFC or eManage to custom tune it yourself.
F
F
Hi guys....
I am alittle new to the forum as I am a hardcore mustang fanatic.....but...
Do the contours take the same Pro-m MAF's as the mustangs? That is as long as they are calibrated for 19#er's
Thanks
Nick
1998.5 Silver Frost SVT Contour One-Off BBS RX wheels, Tinted windows
F
F
I was running lean with the stock MAF, when I installed the Pro Flow it was that much worse! Thank you APEXi SAFC, my car literally feels like a solid V8 now!
I think you shouldnt go any higher the 75mm on a NA tour.
W
W
Depending on the year of mustang MAF, I think the answer is yes.
The SVT's use 19# injectors, standard duratec's use 17#'s.
The only thing is that the maf connector can't be the oval shaped one; it is the more rectangular one.
