Posts: 587 |
Okay.. I try to help out everyone else, whenever possible.. Let's see if I can get a little help, here..
My MTX-75 (E1 SVT) is starting.. correction IS... VERY hard to downshift from 5-4.. I LITERALLY have to PULL.. HARD... I don't wanna force it, as I know this is bad, but I can't get it to come out of gear in any other way.. (Well, with the exception of pulling downwards on the shifer while releashing the clutch... the gear pops out, then.
Shifting upwards is starting to grind, alot, as well..
Walk you through it..
I start in first, as I approach time to shift, clutch goes in (nice and firm, still) I pull downwards to go to second, and it is VERY notchy.. it finally "feels" like it slipped into 2, and then I release the clutch, and "GRIIIINNNND" and the gear pops out..
Slap it back in two, this time it stays.. It is not like the way it was when I got it. I started out slightly notched, but SMOOTH.. now it is HARD. That feeling is in EVERY gear, upwards, to 5.
Once having gone into every gear once, the shift between gears is EASY. (with the exception of 5-4.. a BIATCH...)
What could cause this?
Any other info needed, please tell me..
Ray
Posts: 587 |
Posts: 653 |
I saw Terry at SZ tell someone else that the "notchy" feeling was the throw out bearing. I asked him why mine would pop out of 2nd on occasion, he said it was the synchro's. Hope this helps ya some, Mike
I have a dream, and that is a 69 Boss 302 with Jules Asner in it. Current - 2002 Chevy Silverado Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
Posts: 587 |
okay.. hypothetical..
The situation continues to get worse:How much to fix the tranny?
How much to prevent it from GETTING worse?(Is there even a way?)
Just trying to budget $$ for the upcoming (I know it..) expense.. TIA
Ray
Posts: 5,805 |
Could be 1)Selectors in the tower are starting to slip (the pinch bolt problem) 2)Syncros on the way out,not usual for all to go at once 3)If notchy in all gears ,up & down shifts more like clutch problem,air in the system(bleed it first) ,bad slave or master cyl...do the bleed first.HMS Inc ..616-874-1148
Posts: 587 |
The MTX-God speaks.. thank you terry.. I will search on these "probs" (pinch-bolt. .never heard before) and see what I am looking at.
I will definitely give you a call..
'Thanks..
Ray
Posts: 583 |
Originally posted by Terry Haines: Could be 1)Selectors in the tower are starting to slip (the pinch bolt problem) 2)Syncros on the way out,not usual for all to go at once 3)If notchy in all gears ,up & down shifts more like clutch problem,air in the system(bleed it first) ,bad slave or master cyl...do the bleed first.HMS Inc ..616-874-1148 Damn I wish I lived in MI
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's* B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers. Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
Posts: 1,619 |
Originally posted by Fast4DrSVT: [QUOTE]Damn I wish I lived in MI  [/QB] No, you don't. I lived there for 5 years while in college. You should be saying....Damn I wish Terry lived in Florida!!
95 Mystique LS Young America edition, V6, MTX, Yeah...it's stock. Now with new underhood wiring!!! My Profile Moderator of the Florida Contour Enthusiast Group
Posts: 46 |
Originally posted by MystiqueSVT: Originally posted by Fast4DrSVT: [QUOTE]Damn I wish I lived in MI No, you don't. I lived there for 5 years while in college. You should be saying....Damn I wish Terry lived in Florida!! [/QB]come on the grand rapids area isn't to bad.. other than that thing we like to call "winter"
