car is running very rough the code was 352(Ignition coil B primary circuit fault), and 301(misfire detected-cylinders 1-10) about a month ago i changed plugs and wires, it has been running fine until two days ago, any suggestions?
Originally posted by rac02699: car is running very rough the code was 352(Ignition coil B primary circuit fault), and 301(misfire detected-cylinders 1-10) about a month ago i changed plugs and wires, it has been running fine until two days ago, any suggestions?
just leave your car with me for a few weeks- i'll fix it
99 SE Sport 2.5 Duratec Spruce Green Metallic.. Aesthetic Only.... For Now
...the closest I will ever get to having a Turbo will be the Gillete Mach 3 variety!!!
Interesting......I'm experiencing the very same problem with my 95 mystique V6. The symptom is sparadic and the check engine light is also sparadic. I just replaced the plugs last night and the test drove it and it was actually acting worse. This morning on the way to work, a 20 mile run, it didn't miss a bit??????? I haven't been able to scan the car yet. I'm suspecting now wires or coil pack. It seems to occur at low rpms ( under 3500) under load and pulling out. It is ok under load above 3500. Is this similar to your condition?
that is the same thing that mine is doing, i will being replacing the coil pack tonight if i can get to ford and get the pack will let you know how it turns out
