Y
Y
i've tried doing this with the instructions that are on mods page, and it does not want to work. Any ideas why?
I've done it and it worked fine. Make sure all connections are done properly (splices and soldering).
99 CSVT Green/Tan 13,700Km
# 84 of 2760
For Sale
96 Contour GL 2.5 ATX 120,000Km
K&N Air Filter
Mobile 1
E1 SVT Wheels & BFG G-Force Rubber
Aluminum Painted Front Grill
Also recheck fuses. You have knocked one out while wiring.
"My Name is Richard. I am a Contouraholic."
1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades;
Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod;
PIAA 9006 Super White Headlamps
AIWA CDC-MP3 HU; WeatherTech Mats
Viper 600ESP w/Remote entry
Do the fogs work at all? Check that the relay is properly installed into its socket. And the fuses (already mentioned).
Are you absolutely sure you spliced the right wires? Check it again just to be sure. Might need to crawl under there with a voltmeter to make sure everything is as it is supposed to be. (That doesn't sound fun.)
Y
Y
the fogs work now, 2 fuses burned( idon't know why.....)
thanks
