#732216 08/27/03 06:03 AM
Y
Y2KSVT Offline OP
Y
Ok so I've noticed this for a while and have had nothing come to mind on what it could be. I look back from the driver's seat and can see light glowing through the backseats, coming from the trunk. Does this light always stay on?
#732217 08/27/03 07:05 AM
I wondered about that also, it goes off when the car is turned off so I guess it doesn't matter.
2000 Silver Frost SVT resonator removed 20% tints obx short shifter eibachs & konis ...more to come...
#732218 08/27/03 08:23 AM
My battery wouldn't hold a charge this weekend if the car sat for more than 3 hours. Because of one of the threads I read on this site, my husband decided to check the trunk light -- and just about branded his thumb, it was so hot. He pried the bulb out and we jump started the car again, and it has started every time since. That light seemed to be stuck "on" for quite some time.
Katiecat
'96 Contour GL
#732219 08/27/03 11:36 AM
H
H
Originally posted by Y2KSVT:
... I look back from the driver's seat and can see light glowing through the backseats ..
In previous reports of this phenomenom on '00 models it turned out owner's were simply seeing light from the tail lights, rather than trunk light. In other cases it appeared that trunk light came on with ignition key. None of the threads were conclusive in determining if '99/'00 wiring was different.
On my cars, trunk light solely works from microswitch mounted to trunk latch, visible after removing trim from bottom of trunk opening. If mounting is loose light will stay on.
#732220 08/27/03 12:26 PM
Cheap fix, pull the bulb out so the light will stay out...
or fix the sensor that is suppose to turn the light out when the trunk is closed....
