#730686 08/25/03 08:16 PM
I've got a clarion DB625MP which has 2 sets of pre-outs. If i were to say, hook a LCD display up, would i have to purchase some type of device to allow input into the HU? Would a dvd player act like that? I'm pretty sure pre-outs don't act as inputs. Has anyone else done it where they hook up a separate dvd player in the car?
96 Contour LX ATX Clarion DB625MP 2 "5x7" infinity kappa's in front 2 stockers in back 1 JBL GT 1200D 12' 1 jensen xa2150 pushing the sub *upgrades comin soon
You need a HU with an AUX. input or you can buy my audiocontrol 4.1 eq/line driver which will greatly improve your SQ and has the aux input you need.
Vinny 2000 T-RED CSVT MODS: 18" REV model 2 ST200 struts/Roush springs CTA intake Pipe/K&N Filter Dtec Heatshield Optimized TB True Duals w/ magnaflow mufflers/resonators
ok cool i'll look for those on ebay (i love ebay )
thanks for the speedy response!
othe most common way is to buy a fm modulator. i went this way before i threw in the indash. worked great.
Formaly FLCEGkid Chris Bertrand 1995 Ford Contour Gl 2.5 V6 MTX FOR SALE! Somebody please buy my Fiberglas hood!!
If i were to do a dvd player and an LCD monitor, i'd still only need on modulator or the audiocontrol right since the dvd player will have in's and out's....or is my train of thought off track?
heres a quick break down.
your source(dvd plyer/ps2/ wahtever you want) has 3 outputs: 2 audio 1 video, your lcd will have a power and ground wire with a video input, some come with outputs to run more than one, your fm modulator have 2 inputs for the 2 audio wires from the source, the 1 video output from the source goes straight to the screen, then on the other end of the fm modulator is two antenna wires, 1 connects to the factory antenna wire behind the radio and the other goes into your headunit. And that is that.
well hot damn that makes sense. I understand that perfectly. But would the FM modulator go between the other amps or would it got on a separate rca pre out line? Maybe after all the audio the fm modulator would sit?
it will have nothing to do with the amps or anything else, its soley(sp) dedicated to your extra source. The outputs on the fm modulator go to the antenna input on your headunit so no need for use of more pre outs.
this may help
oops i forgot the pic
ahhhh pics are so nice.
Ok I see it now. The HU acts like a receiver. So hooking up like that would still utilize the subs and amps. I'm 99% sure i'm with ya. The pic helps big time. At least when i get the cash to install i'll have some type of schematic.
thnx a bunch
Moderated by  dnewma04_dup1
