Page 2 of 5 1 2 3 4 5
if anyone mentioned it i didn't notice so i'll say it....u may or may not have to remove the coil pack near the firewall to get to the rear plugs....others didn't have to remove it but i did and i dont consider that i have excessively large hands
when replacing the plugs be sure to use anti seize on the plugs to aid future removal and BECAREFUL NOT TO OVER TIGHTEN THE PLUGS in the cylinders...aluminum heads easily damaged if u thread the plugs wrong
save the money you're going to spend on the dealer doing the work and do it yourself if u can
the instructions provided on this site by the members is good enough for the most part that u can do anything u need to the car far as light to intermediate maintainance
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
easy...just don't do this http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=3;t=007742
the gap wasn't set on my app764's......if you search "spark plugs" you may find after reading that you will want to take those plugs you bought back and get double plats- from what i understand you are left with alot of wasted spark on regualr plugs- that is the only way i know how to explain that- spark gap setter thingies are free at most places- no more that $1 at others. What type of wires are you going to be replacing the old ones with?
99 SE Sport 2.5 Duratec
Spruce Green Metallic..
Aesthetic Only.... For Now
...the closest I will ever get to having a Turbo will be the Gillete Mach 3 variety!!!
Putz Offline OP
someone said to stick with the single ones.. theres a reason for not getting the double or +4
but i dont know why
To be installed:
-New BAT H20 Metal pump (got it)
-Bosch Platinum plugs (got them)
-9mm fordracing wires (on order)
-rear bushings clunk clunk arg!
-Intake when $$ is available
Installed:
-17" BSA Rims and Kumho 712's
-Pioneer Deck and 5x7's
-Side markers, ding strips gone
My ride 98 2.5 ATX : http://members.rogers.com/putz1979/contour/tournoding2.jpg
computer for sale (1800/512meg/60gig.gf3) http://members.rogers.com/putz1979/computer.htm
My autolite APP5344s were pre-gapped. Always check though, wouldn't want to have wrong gap. Too many settlers would try to get through in the winter.
"Wow, that sank fast." "Yeah, like a rock."
96 Contour GL ATX
9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned
Sony CD player: 50wattsx4;remote;
Speakers=50 watt Pioneer 6x8s
Ross Evans smile
Originally posted by Philip:
if you've got normal fingers, you can change your spark plugs and wires without removing the upper intake. you'll see the 3 boots on top near the throttle body, and the other three are under the plastic cam/heat shield.
I have goliath hands and I can get the plug wires off the rear cylinders. Its not easy but is possible. I imagine having a spark plug wire pliers would make things easier.
for the instalation having at least a 12" long extension is nice. And for the removal and instalation having a spark plug socket with the rubber instert that hold the plug makes things easier too. BTW, if you put a little silicone on the spark plug boot when putting it back on it makes it so much easier to press them back on.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
9
9
but i dont know why
Your partly correct... You need a "Double Platnium" plug. This means that there is a coating of platnium on both sides of the plug. This does not mean that there are four of the hook things like on the Bosch +4's. The double platnium is needed because on out ignition system, the spark plug fires in two directions, the standard way, and then the reverse way, basically through the 'ground' part of the plug. On normal plugs, when this second fire occurs, there will be an unusual ammount of wear on the plug where there is no platnium. You really should get those Autolite double platniums. I had the +4's and those *******s were $6 a piece, and were trashed before 20,000 miles (Chris Hightower's were much worse than mine when we all changed them...) Also, definately check the gaps with one of those .99 cent tools. If the gap is too small,. just keep wedging the tool until you get the gap you want (.54) Gap too large, take the tool and tap on the plug until its down to where you want it. And definately do all the work yourself, and save some big money!!!! -Nick
EDIT: I just read your post about stripping the spark plug. When you tighten them down, just tighten until it stops itself, then just give it a little kick to make it hand tight. DOnt go too tight and you wont have to worry about stripping it.
~~~~1999 Contour SE Sport~~~~
-KKM True Rev
-All Cat's fixed.
-SHO Shop Off-Road Y-pipe
-Many other Mod's done...
First off, from www.contour.org, click FAQ -> HOWTO articles -> Maintenance -> How to change the spark plugs on the Duratec V6 The forums aren't the only part of this site - lots of good info resides off the main page.
Taking the coil pack off takes minimal time and makes access to the rear plugs much easier. I guess you don't HAVE to, but it helps. The coil pack is the only part you HAVE to remove (if you choose to) - the intakes stay on.
You want exactly 8" of extension for the rears. Just so happens I have 3" and 5" extension in my socket set. Any more and I think the rear cowl would start to get in the way. Any less and the wrench won't clear the UIM on the back set.
This is the most important part IMHO: Get an inch-pound torque wrench! Don't guess on how hard to tighten the plugs down or you could strip them. Mine cost $40. Sure, it costs a little $$$ at first, but if you want to do any real work on this engine (like removing the intake manifolds, for example) you'll need one. And once you have one, you won't need to pay anyone to do the plugs for you again. Saves money in the long run.
At first, I thought anti-sieze was a bad idea, until I tried to remove a set that I installed without it. After 2 months, they were quite stuck in there. I use it now. You'll get varying opinions on this.
Dielectric grease is your friend. Use it any time you disturb a plug wire from the coil pack or a plug. Cheap tube can be had at Pep Boys.
First time I did it, it took 90 minutes (and it was COLD outside so I kept stopping to warm the hands inside). I'd say 45 minutes to R&R a set, taking my time now.
This is the most important part IMHO: [b]Get an inch-pound torque wrench!
First time I did it, it took 90 minutes (and it was COLD outside so I kept stopping to warm the hands inside). I'd say 45 minutes to R&R a set, taking my time now.[/b]
Is the spark plug torque listed calibrated for the plug as-delivered or with anti-seize? If calibrated for as-delivered, there *might* be a risk of damaging the internal threads in the head(s).
T.
'97 Contour SE 2.5 MTX
Putz Offline OP
damnit
ford said the bosch platinum would work
the PN matches up... but I don thinks its double its just the plain "Bosh platinum" i got
so these thing aint gona last?
To be installed:
Installed:
ARRR stupid wires. I have to buy a new set b/c one messed up. Stupid previous owners put cheap wires on. They used the same plugs I'm using though.
96 Contour GL ATX
Ross Evans smile
