Posts: 653 |
Ok, I'm hoping that I could get a little help.
Within the last few weeks I have cleaned the TB, sprayed some decarb stuff down it's throat and drove for about an hour with the filter off(just messing around to see what would happen). Since then I have been since experiencing some kind of popping/backfiring-thru-the-intake kinda sound and stuttering until 2500 rpm's.
When I had the filter off, it would die when I took it out of gear to come to a light. After the second time, I put the filter back. The car died twice after that, but didn't run as bad. I took out fuses 4 and 11 to reset the computer, let it sit for about an hour, put them back and after about 5 minutes of cranking, it fired up. I let it run for about 20 - 25 minutes then drove it for 30 mins around town. No problems at first. Now, it's doing the stuttering thing mentioned above. It only does this in first gear and doesn't matter whether it's cold or been driving all day.
BTW, it's a 98 SVT.
I've checked all the intake hoses, plug wires and MAF.No codes either or other performance prblems. I did a search and didn't come up with anything definitive. Any help is greatly appreciated. TIA, Mike
I have a dream, and that is a 69 Boss 302 with Jules Asner in it. Current - 2002 Chevy Silverado Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
Posts: 31 |
i had the same thing happen to me, changed MAS, did not help, changed Tb, didn't help, changed cat converter - runs like brand new
Posts: 653 |
The Cat, eh? That kinda makes sense because I used TB cleaner, which I've heard can mess up a Cat. Thanks, Mike
Posts: 816 |
Check the dog too. How do you know what fuses are what number? I tried pulling 14 on the inside once to kill fuel pump, but it killed cd player, mine aren't numbered and i don't have a fuse box cover on the inside.
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 653 |
I checked the dog, but he didn't have much to say other than the cat was playing with the gerbil that was dating the ferret and the ferret told me... oops, said to much. The numbers are underneath the fuse box cover on a diagram. Does anybody know for sure how to check the cat converter? Mike
Posts: 803 |
Originally posted by 69Boss302: I checked the dog, but he didn't have much to say other than the cat was playing with the gerbil that was dating the ferret and the ferret told me... oops, said to much.
MikeLOL Seriously though you drove around without the filter? I hope nothing got into the engine and is now causing a missfire!
hunter green 96 mystique mtx, sabb side markers deep tints car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
Posts: 31 |
Drive the car for a while, so it will get to regular temperature, then you have to look underneath the car and see if the cat is "glowing", it should get red and very hot from all the gas trying to get out.
Posts: 31 |
i forgot, if it's glowing then you need a new one
Posts: 653 |
[/QUOTE]LOL Seriously though you drove around without the filter? I hope nothing got into the engine and is now causing a missfire!  [/QB][/QUOTE] Originally posted by 69Boss302: I checked the dog, but he didn't have much to say other than the cat was playing with the gerbil that was dating the ferret and the ferret told me... oops, said to much. I let a little too much of my imagination out there. I've got issue's. lol @ me I still had the MAF filter in there, so I doubt that. If it's not the Cat, aany other idea's? Thanks again, Mike
Posts: 653 |
I've got to thinking, if the cat was f'd up, don't you lose power? I haven't, at least enough the butt dyno can feel. It certainly wouldn't be my car without issue's.  I think sqplus's bad luck maybe rubbing off on me, Mike
