Posts: 21,653 |
edmunds.com, cars.com, carpoint,etc. often have wrong information, yes you should be claiming more. And changing your timing belt is only needed if your current timing belt is getting worn. It keeps your engine in time (keeps cams at right spots to open the valves) and runs the water pump (on pre98s anyways).
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,465 |
Originally posted by Kremithefrog: and runs the water pump (on pre98s anyways).
my accessory belt runs my water pump
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 21,653 |
crap i forget, maybe mine does too? but you it, crap i'm forgetful, yeah mines does too, right, i think, long day, aahhhhhhhhhhhh
98.5 SVT
Posts: 3,465 |
aka ZetecRacing
Posts: 12 |
Originally posted by SleeperZ: Here's a close up pic of my cam gears;
And here's my engine bay (it has changed a bit from this pic);
I have a 98.5 zetec and I noticed that mine has a cover that goes over the plug boots on the valve covers with a sensor that runs through it. Is it because of the difference in years? Is my zetec different than his? If so what has changed? I have seen a few zetecs but never one with the cover and sensor like mine.
Posts: 21,653 |
98.5 SVT
Posts: 331 |
Originally posted by Kremithefrog: You have VCT, do a search on it. It's on 98+ zetec contours and ,as I've stated before, slows you down 20% as compare to a pre98 zetec.
So does that mean all of us w/ VCT should find a shop that can take it off or should we be doin something different
99 Zetec Atx Se
17's w/yoko H4 rubber
Green and Black interior
CTA + header + big pipes = very loud
89 Mustang LX (stock for now)
Posts: 3,465 |
Originally posted by Monstour: Originally posted by Kremithefrog: You have VCT, do a search on it. It's on 98+ zetec contours and ,as I've stated before, slows you down 20% as compare to a pre98 zetec.
ignore the child.
what the little boy is trying to say is VCT is not a good thing for mods.... it doesn't respond to mods like a non VCT Zetec does.
to remove it is not an easy thing, you can't just flip a switch.
aka ZetecRacing
Posts: 108 |
I believe the VCT was for emissions purposes. Zetecs with VCT don't have an EGR setup.
Posts: 3,465 |
Originally posted by tymeks: I believe the VCT was for emissions purposes. Zetecs with VCT don't have an EGR setup.
correct
aka ZetecRacing
