Quick question for you brake guru's! I don't have a Haynes manual, or Ford CD, and was wondering what the torque spec is for the (2) 15mm Bolts that hold/attach the caliper, as I know the (2) 7 hex bolts that attach the two sections of the caliper housing are 21 ft/lbs. I did a rotor, brake pad change, and just want to return everything to spec.
