#63435 06/16/02 08:52 AM
i got a little problem!! i just had to take my tb off to get the upper intake off to replace a bad valve cover gasket.. and now that everything is back together my gas pedal feels like it's sticking.. as in i can puch it down a 1/4 of the way and then it feels like something is getting hung up but i can keep pushing and it does go past the point and all the way to WOT the car also returns to idle perfectly.. i have no idea whats wrong, maybe the tb needs a little lubrication or something?? any help would be great. this isn't making the car undriveable.. just annoying...
Thanks~ if you help that is laugh
99 SVT with resonatorless exhaust and open element intake
Sound System:
Clarion touch Screen Source Unit
Focal Components,Audiocontrol eq,
eclipse Subs and Amps
#63436 06/17/02 08:54 AM
i think i have something similar with my car...when i drive on the freeway for a length of time and then come to a stop...when i give the car gas it feels as if the pedal doesnt want to move...a little more pressure and it proceeds as normal...feels like the cable is binding
i've been planing to buy another throttle cable but im not sure i wanna tackle trying to install it
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
#63437 06/17/02 09:06 AM
I've always had the same problem, on both my stock TB and my new 63mm one, especially after running hard. I figure it's just junk making it stick closed slightly. I have to make sure to blip the throttle after running a 1/4 mile before I make the turn to the return road (with the clutch in) to unstick it because it gets REALLY stuck then.
I have felt the same resistance with the TB off, so I'm convinced it isn't the cables. Happens if the TB is freshly cleaned or not. Probably just a "feature" of the Duratec's fuel vapor recovery system.
#63438 06/18/02 04:17 AM
E
E
Hi,
Can you operate the TB freely by hand...any glitches then? If so, check the cruise control cable for kinks. When you operate the normal throttle the cruise cable attach point slides along it's cable. If there is a kink in the CC cable it might cause a glitch. Check also the TB return springs for binding. If the TB does operate freely by hand, go inside and check for any obstructions under the dash...hanging wires, sound proofing material, carpet, etc. If nothing there check the throttle cable by holding the TB WFO and remove the cable from the cable guide drum. The cable on mine will easily allow the pedal to fall to the floor when released. If yours doesn't, you might need to un-kink, lube, or replace the cable. A remote possibility might be the TPS or the TB shaft might have a dirty bearing/seal. Remember, "The first thing to go wrong is the last thing you fixed" That's always my troubleshooting motto! laugh
...Ed
2000 Silver Frost SVT
#1625 14 Jan 2000
Dual Mode Dampener
A/C switched
K&N Dropin
Magnecor
#63439 06/18/02 04:22 AM
There is a RECALL on the accelerator cable, you know...
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
