That's only to be done RIGHT before you dump the oil, AND you should not load the engine AT ALL (i.e. try and drive it with that stuff circulating around) or you'll fugg it up ROYALLY!
It works just like any other engine flush:
Dump it in the oil, run the car at idle for 5-10 minutes. dump the oil, remove the oil filter and refill with new oil and new filter.
