After battling water in the passenger side of the trunk for over 6 months, I have finally decided to remove the rear bumper and seal the passenger vent correctly. I tried to seal it from the inside, but I think I did a sloppy job because of the limited space to work in. Water is still coming in, but not as much. I had also discovered a leak in the antenna housing on the outside of the car which I fixed earlier this week. What luck!
I printed the How To for bumper sag(which I do have as well, but not for long
), but I was just wondering if anyone had some tips or advice for me. I've heard you can remove the stuff in the vents to stop the buzzing in the trunk when playing subs. Should I do it? Thanks guys. I'm going to be sealing both sides as a preventative measure. :rolleyes:
