Finally, I had the notourious hesitation while the car was under load below around 3K. Here is a snapshot.
Hesitation started after replacing OE plugs only with Autolite pp's. I blamed plugs wires then switched from OE to 9MM, no change. Then I replaced coil pack, fuel filter cleaned TB and KKM intake, performed UIM/LIM cleaning, nothing changed. After tolerating for a while I switched plugs again thinking maybe a faulty plug, no change. After many hours after tinkering around with secondaries, vaccum tubes, etc all seemed to be operating normal. I was leaning toward fuel pump as my next attack. While surfing this site as I have done before I happenned upon a post by "Kennard" who very enthusiastically fixed his hesitation in a zetec by going back to the Motorcraft plug. Well, I finally made the trip to the dealer and I can't beleive the difference. smooth as butter. I highly recommend to anyone with a similar problem to get the Motorcraft plug. I guess I've read on here that Autolite makes the Motorcraft plug or vice versa but they do look very different at the electrode tip. I have a 99 2.5 SE my plug was AGSF32FM they are single plat but I'll gladly switch em out a little earlier than the pp's. They are performing extremely well in my Duratec. Hope this helps anyone with this problem.
99 SE MTX KKM intake res removed Diablo Chip Ford 9mm sport wires
