Posts: 29 |
I did the TH fix and it worked well. I ended up with a hole of .199" with a #8 drill after starting at .160" and stepping up approximately .010" at a time. The tach now drops immediately to 750 with a millisecond pause at 1,000; I'm estimating the "millisecond". I am very happy with the TH fix and notice no loss in power at all. Problem: I live on a steep hill and usually let my SVT go down in first or second gear without any throttle. My throttle sticks closed by the time I get to the bottom requiring an extra tap on the accellerator to free it. This now happens almost everytime I use engine compression to slow down for an extended period, ie., 10/20 seconds. Naturally this "sticking" didn't happen before the TH fix because my engine would rev up as high as 3,000, then drop off and rev again. Any advice? John 98 SVT
John Black '98 CSVT #2000 of 6535 Sometimes good, sometimes bad Sometimes hate it, mostly love it No mods other than 225/45-17 tires
Posts: 884 |
You're just gonna have to go with a bigger hole. PPL at higher altitudes, like myself, are gonna be prone to this irk. Just make it slightly bigger. It may not drop as quickly but it should drop quicker than it does stock.
HTH John
Posts: 29 |
Today, I took the rubber bellows duct off to clean the throttle body with throttle body cleaner. HAH! There is a factory sticker directly under the hose on the tb so you can't possibly miss it. The sticker says, explicitly, do NOT clean the throttle body because of the coating. Duh? So, I increased the hole size in my TH fix plug to .218" from .199" I still have the throttle sticking after using engine compression to slow down. It only takes a slight nudge to free it but it is still annoying. It definitely feels mechanical, the same as a carb feels when the throttle plate sticks due to the stop being backed off. Any more ideas?
Posts: 229 |
Clean the throttle body and ignore the sticker. It is a load of BS. There is supposed to be a teflon coating to prevent deposits on the TB. It doesn't work worth a s**t.
99 CSVT Green/Tan 13,700Km # 84 of 2760
For Sale 96 Contour GL 2.5 ATX 120,000Km K&N Air Filter Mobile 1 E1 SVT Wheels & BFG G-Force Rubber Aluminum Painted Front Grill
Posts: 116 |
Yes, definitely clean the TB anyways, and while your in there, make sure that the throttle plate isn't binding in the throttle bore because it's closing too far. If it does bind (i.e. feels like it sticks until you crack it open), then adjust the base throttle plate set screw 'in' slightly more until the throttle plate can close, but not enough to bind in the bore. Comprende? Good. Then after doing that re-adjust your TPS sensor to have like .94-.98 Volts at base throttle setting (KOEO) to maximize response (but NEVER set it over 1.00 volt). The factory sometimes has these as low as .6 or so volts. But the point of checking it, is to make sure that when you adjusted the throttle plate more open (to elliminate binding), that you didn't bump up the TPS voltage to go past 1 volt (which switches the computer into 'off idle' strategy). Then you'll probably have to re-calaberate the orfice size of your hole on the TH fix plug
'95 CONTOUR SE -Enkei 16s -Porsche944 Exhaust tip - Audi xenon projector headlights -Peterbilt 30" air horns -mp3 Aiwa headunit (150 songs on one disc) -dual 10s -soon to have LED tailights (real kind, not just gay bulbs) -That's it for now
