Posts: 101 |
It cost me less then 1/4 to do the pipe then buying a y-pipe for those thrifty types out there...
96 contour SE,E1 rims w 205/60/15 Comp TA's VR4's,optimized y-pipe,SVT doorsills,KKM intake,BULLIT MUSTANG fuel door,painted grill,every available option w/leather !
95 mystique LS,every option minus leather,optimized y-pipe+exhaust
Posts: 873 |
Originally posted by 96SEMAN: It cost me less then 1/4 to do the pipe then buying a y-pipe for those thrifty types out there...
Yeah, I know, I did mine for under $10. Problem is people are wanting others to do theirs. I just don't see that happening. I want to warn anyone who gets suckered into doing it for someone else that it is a bigger pain in the ass then what it may seem, expecially if you start breaking studs. Mind you, I broke 3 of my studs and I don't live in a place where they salt the roads. Funny thing was that the y-pipe had been off a week before since it was in the shop for a manifold change (Ford could have F'ed something then).
2004 Focus PZEV 2.3L - KW sport suspension, SP camber plates, Eibach front swaybar, FS intake, FS Stealth exhaust, 3.82 Final, Torsen ATB, Prothane MM insert, E1 CSVT wheels
1/4 mile - 15.201@89.4mph
Posts: 2,469 |
i read the how to 10 f'ing times on the main page and it still makes no sense. Does anyone have pics or something?
Posts: 101 |
Go to warmonger's 3L site off the links and follow his instructions and pics for a general idea Any muffler shop should be able to do it for ya following the instructions-it's well worth it!!
Posts: 2,469 |
war. did this
the how to talks about getting a 6" peace of 2.5 inch pipe and have one side flanged, wich i dont understand were that fits fits in the equation. war. just cut out the crushed pipes and replaced it with lots of weld. Wich prob. works just as well.
Posts: 5,810 |
 Those welds aren't as big as they look, I used the grinder quite a bit to erase my welding mistakes since I was learning to weld on that project! By this I mean that I didn't have to fill any large holes, I just sucked at welding then. I got a lot better by the time I tackled all that pipe welding for my turbo. I just cut the piping with a die grinder at angles to where the two pieces would butt up together then welded them together. Making a smooth transition was perhaps the hardest part. after they were together I just cut the joined pipe off flush and added about 2" of 2.5" pipe to lengthen it and stick back into the flange. The flang accepts 2.5" ID pipe IF you cut out the old pipe. war...
See My Mods
Posts: 2,353 |
Originally posted by 96SEMAN: Go to warmonger's 3L site off the links and follow his instructions and pics for a general idea Any muffler shop should be able to do it for ya following the instructions-it's well worth it!!
The problem is that here in Cali, no shop will touch your y-pipe. The state regulations have become absolutely ridiculous. You have to do it yourself or find somebody that can.
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
Posts: 101 |
Can't you travel into the next state and have them do it and then go back? It might be a pain but the results are well worth it....
Posts: 2,397 |
Originally posted by path914: Originally posted by 96SEMAN: Go to warmonger's 3L site off the links and follow his instructions and pics for a general idea Any muffler shop should be able to do it for ya following the instructions-it's well worth it!!
Take it off the car and try it I think then you could get a muffler shop to hook it up. Or take it off the car and go to a machine shop/welder that isn't a car guy.
Formerly known as Sneaku
I MISS MY BABY!!!
'00 Blk CSVT #1087/2150 built 12/23/99
Posts: 7 |
The guy I know at the Mr. Muffler by my house said he can make me a Y-Pipe that would flow alot better than the one I have for about $150. Sound like a good deal? Or should I try and give him Warmongers instructions? Either way would this be worth doing performance wise? And will this make my Borla Catback sound any deeper?
1999 MTX Cougar
Stainless Borla Cat Back
SPEC stage 1 Clutch kit
Reverse indiglo guages w/brushed aluminum bezel
Polyurethane front sway bar/motor mount bushings, Dual Mode Dampener
NEXT: Cold air intake
