Posts: 1,359 |
I was just wondering if this is normal.....my CSVT after being driving for about 15 minutes or more will be pretty darn hot. For example, it is probably too hot to touch (at least for a long period of time).....you can feelt he heat radiating from the engine bay with the hood up. As far as the temperature gauge in the dash.....it reads normal....the needle is usually right in the middle. So is this heat normal for this engine?
98' Contour SVT
#607 of 6535
05' Mazda 6s
Audio/Visual enthusiast because it's one of the many things I went through 4 years of hell for
Posts: 655 |
The engines on all of the Contours/Mystiques we have had were very warm to the touch. My 1999 SE Sport Duratec runs in the middle of the temp gauge (11 o'clock), so did our 1998 Mystique Duratec, and our 1998.5 SVT. I don't have anything written on my temp gauge (the 99 SE Sport). Every other Contour I've seen has NORMAL written on it, the needle usually points between the R and the M. I always wondered why mine has no lettering. Anyone else have a Contour or Mystique with no lettering on the temp gauge?
Posts: 611 |
I have always noticed that all the Duratecs run pretty hot. The SVT even more then the regular ones. Sounds normal to me.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
Posts: 1,359 |
Good to hear, I just wanted to make sure all was in order especially since I just replaced my water pump (had to take the thermostat out in the process) and I wanted to make sure I didn't mess anything up. Thanks for your help
98' Contour SVT
#607 of 6535
05' Mazda 6s
I am Canuckian
I am Canuckian
Posts: 4,168 |
My gauge reads no higher than the o of normal and usually has a hard time making it to the n on the highway. That is in the Duratec. The Zetec on the other hand frequents the a of normal on the gauge. Not sure if that helps you.
Green 96 mystique gs 4cyl mtx
16.9 in the 1/4 mile @102500 miles
95SE in Midnight Red MTX
MSDS headers and y-pipe
SVT exhaust
SVT UIM
Optimized se TB.
Full pre 98 SVT body kit
15.741 @ 87.73mph :)
Posts: 1,881 |
Originally posted by bullion: I was just wondering if this is normal.....my CSVT after being driving for about 15 minutes or more will be pretty darn hot. For example, it is probably too hot to touch (at least for a long period of time).....you can feelt he heat radiating from the engine bay with the hood up. As far as the temperature gauge in the dash.....it reads normal....the needle is usually right in the middle. So is this heat normal for this engine?
My SVT acts the same exact way. It's normal.
1998 T-Red SVT #957
Born 5/14/1997
Posts: 9,602 |
My engine temps range from around 170 in normal driving to 190's in rush hour traffic. (I.E. stop & heatsoak then repeat!) Definitely MUCH better then how it came from the factory...
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 6,910 |
Originally posted by mbb41: My gauge reads no higher than the o of normal and usually has a hard time making it to the n on the highway. That is in the Duratec. The Zetec on the other hand frequents the a of normal on the gauge. Not sure if that helps you.
of the three duratec's may family has they all sit right at O in Normal. the only time anyone here has sen one move was when the waterpump failed in my fathers car.
also the normal on the dash is on all pre 98 dashes. The lettering was decontented in the post 98 models
look below to see how I made the compairison
- 95 Mystique LS - Zetec/5spd
Posts: 15 |
My temperature usually ranges between 195 and 205, sometimes as high as 210 around town on a warm 85-90 degree day.
2000 MTX Cougar
Custom Dual Exhaust, Supercharged Contour SVT Engine (returnless), 75mm Pro-flow, oil cooler, Stage 3 SPEC, MSDS, Magnaflow HighFlow cat. Alpine monitor with Nav., XM. B&M Shifter. OMP Cross drilled and slotted rotors.
259.33 FWHP
Posts: 96 |
go to a race shop or a autoparts store and get some "redline racing water wetter" put that in. then wire both of your fan to a switch so you can keep the running that will help out the most..i did that to my CIVC and it ran alot cooler. i am just to lasy to do it to the SVT//
98 SVT, clutch masters flywheel, spec stage2 clutch, quaife ,y pipe. and only MOBIL-1 oil.
gansta a$$ 2000 Honda Civic on dope("nnnaaawwwzz").
ricers suck
KING OF ROAD RAGE
i need a center console and cup holder!!!!!1
