i know the how to procedure. that isnt my question. what im asking is how do i connect the vc to vc connection. if i'm using twisted speaker wire, one neg connects to the neg post inside the box. the pos is connected to the pos inside the box. the neg is connected to the neg inside the box. then i run the pos end of the twisted wire to the pos of voicecoil1, the neg end of twisted wire to neg of voicecoil2. how do i connect the in between part, the "series" part, the neg on vc1 to pos on vc2. do i use twisted wire for this part or pull the twisted wires apart and use it to go vc to vc
i looked at my stryke av12. i thought the connections used rcas but testing it into my box and looking closely, the connections are like push in. i guess i just expose the speaker wire and put it thru the open hole. can anyone else confirm this.
