Posts: 28 |
i have a 00 contour sport with spoiler i ck and tightened it but yet mositure just keeps soaking the trunk can't find the leak anywhere help if u can thanks
Posts: 1,165 |
Woah!! Damn...once is enough.
I live in Detroit, I couldn't give a **** how good my car is in the "twisties."
"I could use a hundred people who don't know there is such a word as impossible."
~Henry Ford
Posts: 135 |
I had a problem with my 99 V6 SE, i took it to ford and they told me they would water test it for me for like $100, and i was like to hell with that, ill do it myself. i got in the trunk with a flash light and had a buddy pressure wash the back of my car (at a coin op place) and low and behold it wasn't the trunk at all, it was coming in from a poor seal in the window. i had the window re&re'd for about $100 cdn, and when the took the back window off a strip of about 4-5 inches of sealer was never in contact with the body of the car. just a thought. the water was coming in though the hinge on the drivers side. hope this helps!!
Posts: 2,319 |
Loose spoiler has been the subject of several threads, however, I've never seen it mentioned as a source of leaks. Most sources mentioned in the below thread, including rear window seal mentioned above.
trunk leaks
Note: Your three extraneous multiple 10:00pm posts have now been deleted, perhaps a software glitch.
Posts: 1,110 |
Originally posted by ZER0: it was coming in from a poor seal in the window. i had the window re&re'd for about $100 cdn, and when the took the back window off a strip of about 4-5 inches of sealer was never in contact with the body of the car. just a thought. the water was coming in though the hinge on the drivers side. hope this helps!!
Exact same deal with mine(trunk leak 1 of 3 ) but on passenger side.
'01 Escape XLT V6 on S100
CDT Audio/Ascendant Audio/Rockford/JBL/Knukonceptz setup
'00 SE Sport ATX
Posts: 42 |
I have the same car that had the same problem. Chech the trunk vents!
Posts: 465 |
I was fooling around with that trunk vent the other day because my trunk has been leaking. The rubber strip came apart in my hands-I'm thinking that was the cause. But someone said in some forum that you have to take the bumper out to properly remove the vent. There's got to be another way.
Old car: '98 SVT T-Red
K&N air filter; Ford Focus RS shift knob. Off to be auctioned off somewhere.
New car: 2003 Honda Accord DX Sedan, 5-speed.
Posts: 133 |
Originally posted by NickP: I have the same car that had the same problem. Chech the trunk vents!
OK, you offered, exactly how do you check the trunk vents. Our trunk has been wet on the drivers side ever since we bot the car, I always assumed it was the trunk seal, since we have no spoiler. So how does one go about doing as you suggested ?
Ken, 99 Silver Frost SE Zetec Atx, polished alloys, Kumho's, Pioneer hi power CD/AM/FM. Factory spoiler (added) Audi side lites, Borla stainless steel muff. Stolen, recovered in pieces. Looking for another Tour, preferably V6, 5 speed.
Posts: 306 |
I had water in my trunk also. What i did was take the lights off sprayed some spray adhesive on the back of them and silicone the top where the rubber stops are for the trunk. Around the black thing. Kinda hard to explain.
98 CSVT Black
Alpine CDA 7995
Memphis 1000D & Alpine MRV T302
2 Orion 12's
HPP Rear Strut Bar
Posts: 154 |
I had the same problem and it was the trunk vents. I think you can see them behind the trunk carpet lining on the sides of the trunk. To repair the leak I recommend that you remove the rear bumper which is really not very difficult- just a few bolts here and there, maybe a screw or two in the wheel wells, and the thing pops right off. Once you do that you will have easy access to the trunk vents on both sides. Pop the vents out, remove the rubber/foam seal and replace with gobs of black RTV sealer. Let dry and your problem should be solved. Just remember to put the bumper back on.
-svtdc-
'98 E0 silver frost SVT - SOLD
Mods: DMD, Mobil 1 oil and filter (is this a mod?)
