Is it just me or does the carpet pull away from the door trim on the bottom way too easily? What do you folks do to keep the carpet under the plastic door trim? Man it looks like crap! Any suggestions will be appreciated.
I had this problem on the front passenger side. It looks like the carpet is a little small or has shrunk. I fixed mine by adding a piece of leftover home carpeting under the carpet. I cut a piece to match the contour of the floor area and put it under there. This was thick carpet I used, carpet pad would be good too. Anyway it gave enough of a rise that the factory carpet would tuck nicely and hasn't come out since. I don't notice any other difference from this either. My kind of fix (cheap and quick).
