How do you remove the antenna? I have been trying to fix the leak in the trunk for months now and after a lot of frustration(and silicone...lol), I found out it was the seal on the antenna. I tried to seal it from inside the trunk, but it still leaks. I think I'll have to remove the antenna and put a little bit of silicone under the rubber part(which I do not want to do while still attached to the car) on the outside. Any clue? Thanks.
Edit: BTW, it is not a power antenna, and when I say antenna, I mean the housing the antenna screws into.
