My 98 CSVT has been cutting off when I hit the brakes hard. Also, it won't turn over sometimes. I had the battery and alternator tested at two different locations, and both said they were fine. Sounds like an alternator to me, but could it be a short in the electrical system somewhere? Is this an ignition problem? I'm getting the 4-4 code for a dirty RF airbag sensor, could this be causing the car to cut off and not start? If anyone has any insight, I would appreciate it. Thanks in advance, guys.
98 CSVT black/midnight
Trubendz catback, BAT inlet pipe, 75mm Pro-Flow, K&N open air on SCA cold air pipe, Optima Red Top in trunk, short shifter, Richbrook e-brake, lowered, side markers, mesh grille/bumper inserts
