Check your backup light switch to make sure it is functioning properly. The Haynes manual says that for manual transmission Contours, (which I assume yours is by your screen name of SVT- you didn't specify otherwise) it is located in the engine bay on top of the transmission. The instructions say to remove the air cleaner and mass airflow sensor to get to it, which should point you in a general location.
