Posts: 1,001 |
i've done 10000 searches, 9345 to be exact, and i can't decide how i want to paint my chrome ring and my rear reflector. i went to a auto store and asked, and the guy seemed to know what he was talking about. i bought some bumper paint, its a glossy black, and flexible, and some 3M 600 grit sand paper. he said to scuff stuff with paper then just do a few coats with black. no need for clear because its glossy, so he says. will this work? wont it? thanks.
Posts: 4,220 |
Well, the process is right, but I'd get something that matched my color a little better than some generic glossy black paint, including some clearcoat to at least try to match the factory finish.
2003 Mazda6s 3.0L MTX
Webpage
2004 Mazda3s 2.3L ATX
Posts: 119 |
those two items are relatively rigid so you shouldn't have to use bumper paint, or flexiblizer or anything like that.
sand off the chrome on the ring, until you get to bare plastic. use a fine grit, say 5000, and keep dunking the paper in water (make sure you have wet-sanding paper). do the same for the reflector, it doesn't have to be totaly scratched up, just kinda foggy...
good luck.
what's the silver frost paint code, if i wanna get a can of spray made??
Posts: 8,301 |
paintscratch.com--for the Silver Frost.
-Ken V.
psycho_bass@hotmail.com
Posts: 295 |
5000 grit? That seems awful high. I usually use 400 grit to just scuff it, then use a couple of coats of automotive primer, then spray a few light coats with whatever, then clear it 4 - 6 times, then go back through and wet sand it with 1500 or 2000 grit, then hit it with some Meguiars (or other) nice wax and buff it to a purty shine!
-Jonathan
Jonathan
'96 Contour Zetec MTX
208,XXX miles
Posts: 2,241 |
bumper paint will resist big bugs / rocks better too mind you..
-Matt
"Pain heals, chicks dig scars, and glory lasts forever!"
will do/pay just about anything for the following parts:
CF sunroof glass replacement
OEM CF trunk
Non OEM style cf or fiberglass hood not the cf1 design
Posts: 1,616 |
Originally posted by Jonathan: 5000 grit? That seems awful high. I usually use 400 grit to just scuff it, then use a couple of coats of automotive primer, then spray a few light coats with whatever, then clear it 4 - 6 times, then go back through and wet sand it with 1500 or 2000 grit, then hit it with some Meguiars (or other) nice wax and buff it to a purty shine!
-Jonathan
He probably meant 500 grit...
5000 grit would be like a cotton ball!
Posts: 1,001 |
i'm havin my friend do it for me because he says he knows what hes doin. lets hope so!
Posts: 17 |
I talked to home depot and all they have is Rustoleum. So what i am thinking is paint the rear reflector with the rustoleum and then clear coat it. This should not be a problem should it, I would think the rustoleum would work??
Posts: 2,975 |
RUSToleum. I'm just taking a stab at it but would this product be for METAL....not plastic painted chrome rings???
1992 Ford Escort LX-E
-Tracer LTS spoiler
-GT Grille
