The runners never have to be replaced!! The only thing if any is the imrc controller (the little box covered by plastic on your left valve cover) what happens is there is a little white plastic spool inside the box that commonly breaks and locks the runners in place, I would check this first, the box can be opened by just unscrewing the four top screws and prying the top of with a screw driver. if that is not the problem let me know and I will check those trouble codes out for you.
98 Contour SE 3.0L 5-speed
SCT PRP, Gutted IMRC's, Fidanza Flywheel, Race Ported 2004 3.0L Oval Port, Zex 125hp shot, 70mm Mustang TB, 42Lb injectors,Walbro 255 pump, Traction Bars, Zeitronix wideband o2, lots of little things, 10,000K HID's!!
