If you could be more descriptive with the problem I might be able to help more, but one common problem that I know of is that the pre-cat blows out and plugs the exhaust, and the car will have no power, also have someone check the plug wires and fuel filter (I found a few contours that I have worked on have had little dried up bits of factory sealant clogging the filter)
98 Contour SE 3.0L 5-speed
SCT PRP, Gutted IMRC's, Fidanza Flywheel, Race Ported 2004 3.0L Oval Port, Zex 125hp shot, 70mm Mustang TB, 42Lb injectors,Walbro 255 pump, Traction Bars, Zeitronix wideband o2, lots of little things, 10,000K HID's!!
