Posts: 10 |
Greetings everyone.
I need advce on this one and fast. I have a 1999 Contour SVT bought 2 weeks ago at Carmax in Stockbridge GA, (not a good experience.) Aside from the intermitent CEL appearances and the broken sway bar connector that they can't get to until Tuesday but they diagnosed it on Memorial day, on my way home last night Iwas sitting at a stop light and glanced down and my speedometer and odometer were acting as if I was driving as normal even though I was at a complete stop. I was curious to see if anyone else has been afflicted with this issue. Thanks for your help guys I truly appreciate it.
1999 Contour SVT Toreador Red 15% tint and much attitude...
Posts: 1,040 |
Originally posted by Holly would: ... Iwas sitting at a stop light and glanced down and my speedometer and odometer were acting as if I was driving as normal... You mean they were showing speed and recording miles while you were standing still?
Posts: 1,461 |
Disconnect the vehicle speed sensor and see if that makes the problem go away. If so, it's probably that.
Brian
Posts: 10 |
Not being mechnically inclined where would I find the vehicle speed sensor?
Posts: 78 |
It's on the tranny, IIRC. Honestly, I don't know enough about it to describe it real well. You may want to try to get your hands on Haines manual.
'98 Contour LX-White 2.5L ATX 73,250 miles KKM Tru-Rev / FMS Wires & Bosch +4s 19mm BAT rear swaybar
Posts: 816 |
Maybe u'r were trippin' on acid and forgot u were trippin' on acid, and u imagined u'r contour has problems. That's it, every1 is on acid, contours r great and have no problems.. Am i on acid? how can what i type be correct then? ignore everything i type.
"Wow, that sank fast." "Yeah, like a rock." 96 Contour GL ATX 9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned Sony CD player: 50wattsx4;remote; Speakers=50 watt Pioneer 6x8s Ross Evans
Posts: 731 |
how can what i type be correct then? ignore everything i type. Don't worry, I'll ignore it, no problem there. Please tell me that you haven't procreated yet though. :rolleyes:
Posts: 10 |
I disconnected the battery for an hour yesterday and I have not had a repeat of the demon speedometer and odometer but it is going back to the dealer on Tuesday and I'll let them "try" to figure it out. Thanks for the advice guys and Redcon96V4 the first step to recovery is admitting that you have a problem. Get help... quickly.
Posts: 401 |
i had a saturn that did that once- it ended up being the alternator going bad
99 SE Sport 2.5 Duratec Spruce Green Metallic.. Aesthetic Only.... For Now
...the closest I will ever get to having a Turbo will be the Gillete Mach 3 variety!!!
