Posts: 29 |
Recently got the P0300 code which pushed the CEL to illuminate. Has anyone had experience with this single code appearing, not in combination with any others. Did a search and not much came up so I am asking here. It's a 1998 2.5 5 speed Mystique. A while ago I also got a camshaft position sensor circuit fault error but not lately..
Thanks!
John
98 Mystique 2.5 5 Speed
Bridgestone Potenzas
New upstream O2s, new CamPosSens
JVC CD DECK, PIONEER SPEAKERS
Posts: 9,602 |
Those two failures go hand in hand.
Random miss fires and a cam sensor problem.
I strongly urge you to get that problem fixed before it randomly fires too early too often!
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 29 |
You have advised that I get it fixed, what is, in your opinion, broken? Should I replace the cam position sensor or what..
John
Posts: 1,508 |
Originally posted by jcmac: You have advised that I get it fixed, what is, in your opinion, broken? Should I replace the cam position sensor or what..
John
That is what he is saying. Replace you sensor before you ruin your engine.
1998.5 E1 SVT Contour #5482/6535
Posts: 29 |
Well, I just removed and "tested" the resistance of the sensor and obtained a reading of 370 ohms which is within the expected range of 200 to 900 ohms as stated in the Haynes manual. Is there another test for this item or is it now "OK".
The coil pack is next on the agenda. Does anyone know of a test for it or for the spark plug wires. Please advise as I would much prefer to replace the wires than the coil pack.
Regards,
John
Posts: 29 |
Well have replaced the sensor, got the P0340 code again, what next?
Posts: 635 |
If you don't have a manual,Possible causes:
-- CMP circuit open.
-- CMP circuit shorted to GND.
-- CMP circuit shorted to PWR.
-- SIG RTN or CMP/TSS GND open (VR type).
-- VPWR open (Hall effect type).
-- CMP Sensor (Hall effect type) not installe correctly.
-- Damaged CMP Sensor.
-- Damaged PCM.
If engine will start l Complete PCM Reset to clear DTCs.
l Start engine.
l Increase rpm to greater than 1500 rpm for 10 seconds. Repeat two times.
l Key off.
l Retrieve all Continuous Memory DTCs.
l Is DTC P0340 present?
Yes For VR type CMP:
GO to «DR5».
For Hall Effect type CMP:
GO to «DR3».
Not sure which type or how to ID which type????
DR5 DR5 CHECK FOR OPEN CMP AND SIG RTN CIRCUITS BETWEEN PCM AND CMP SENSOR
l Install breakout box, leave PCM disconnected.
l Measure resistance of CMP circuit between PCM test pin 85 and CMP sensor harness connector.
For VR type CMP (Contour/Mystique, Escort/Tracer):
-- Measure resistance of CMP/TSS GND circuit between PCM test pin 76 and CMP sensor harness connector.
l For VR type CMP: (All others:)
-- Measure resistance of SIG RTN circuit between PCM test pin 91 and CMP sensor harness connector.
l Are resistance measurements less than 5.0 ohms?
Yes GO to «DR6» DR6 CHECK CMP CIRCUIT FOR SHORT TO POWER IN HARNESS
l CMP sensor disconnected.
l Key on, engine off.
l Measure voltage between PCM test pin 85 and PCM test pins 51 and 103.
l Key off.
l Was voltage less than 1.0 volt?
Yes GO to «DR7». DR7 CHECK CMP CIRCUIT FOR SHORT TO GND AND SIG RTN IN HARNESS
l Disconnect scan tool from DLC.
l Measure resistance between PCM test pin 85 and PCM test pins 51, 91 and 103.
l Was each resistance greater than 10,000 ohms?
Yes GO to «DR8». This just keeps on going and going and going. this is from Ford CD manual. Well part of it.
Personally I've never had this trouble, but from Demon said, I wouldn't mess around to long and get it to the dealer before it damages something. Paul
Paul
98 Mystique LS 2ea (07/97)(08/98)
