Posts: 2,127 |
I think one of the suggestions was to use electrical contact cleaner to clean the "hotwire" in the MAF.
TB
"Seems like our society is more interested in turning each successive generation into cookie-cutter wankers than anything else." -- Jato 8/24/2004
Posts: 79 |
Just replace the O2 sensor and see where you stand...
Posts: 34 |
Like the others have been saying you need to clean the hot wire inside your MAF meter. It sort of looks like a light bulb filament. There are two in my zetec MAF.
I used electronic contact cleaner to clean the "filament" , the contact cleaner leaves no residue. I did not clean the contact on the wire connection or harness.
You might spray the "filament" with a stronger cleaner like electric motor cleaner or brake cleaner before rinsing it with the electronic contact cleaner.
'96 Mystique GS 2.0L ATX
Posts: 1,631 |
Originally posted by tom: I did not clean the contact on the wire connection or harness.
My bad. I thought u guys were talking about the electrical connections.
Anything is POSSIBLE... sowing the seeds of love"
Posts: 974 |
Originally posted by tom: Like the others have been saying you need to clean the hot wire inside your MAF meter. It sort of looks like a light bulb filament. There are two in my zetec MAF.
Best stuff to use, Berryman's B-12 Chemtool!!! It rocks!
Cleans and then evaporates!!
Spray it down, wait, then spray it again. Using an open element, or cone filter? Replace or clean it sooner...speaking of which, I have the Spectre, I will probably be replacing mine again soon. Every season change, I change the air filter.
L8R Rich
'04 Ecotec Cavi 140hp/150tq Fabbed intake. Header Coming, DRL's disabled, X-Drilled/slotted rotors coming....Man you really are fast. You were hauling a$$ when I passed you
RB&LB
causing problems in Huntsville
Posts: 682 |
I just cleaned mine with Chemtool. I put the plastic tube into the squirt nozzle and aimed the jet of fluid at the two wires, and they came clean without having to be touched with a swab. And the fluid didn't come out at dangerous pressure.
Of course, Chemtool can cause cancer, but you'll probably be okay.
Posts: 21,653 |
I've seen some b-12 at store but are there two types of B12 cuz it doesn't look like others I've seen ppl post pics of.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 1,631 |
Originally posted by sosaudio1: Using an open element, or cone filter? Replace or clean it sooner...speaking of which, I have the Spectre, I will probably be replacing mine again soon. Every season change, I change the air filter.
L8R Rich
what is it the you'll be replacing ??
The MAF ????
I should replace the MAF everyyear because I have the CTA ??
Posts: 1,631 |
Originally posted by sosaudio1: Best stuff to use, Berryman's B-12 Chemtool!!! It rocks!
Okay,
I've been looking around for this B-12 stuff, but it seems like you guys are really talking about this (2206) ELECTRONIC CLEANER and not the B-12, because B-12 is a Carburator Cleaner !!!
Can someone clarify this thing ????
Here are the Berrymans products:
Berryman
Thanks
Posts: 21,653 |
Originally posted by BBorges: Originally posted by sosaudio1: Using an open element, or cone filter? Replace or clean it sooner...speaking of which, I have the Spectre, I will probably be replacing mine again soon. Every season change, I change the air filter.
L8R Rich
The MAF ????
NO
98.5 SVT
