Page 3 of 3 1 2 3
#711480 08/15/03 06:30 PM
Rob,
I would suggest that you find a new place for your tranny work. Perhaps someone more acquainted with the CD4E and the reason for the shift kit. Also to suggest that dropping the tranny is easer then removing the T-Stat indicates that he doesnâ??t do a lot of tours. Dropping the tranny requires lowering of the U-Frame, Disco of the PS lines at the rack and a wheel alignment when finished. Lots of potential for things to go wrong. Granted, that leaving the tranny in makes it slower to remove all the side cover and VB bolts, but its got to be better the wrestling with the U-Frame.
I have the SK-CD4E jr instructions all zipped up 3.28 Mb.
Pete, my limit on the site is 3Mb. Do you want me to e-mail them to you or can you kick my storage up to 4 Mb?
jeff
have you fixed your ford lately?
#711481 08/17/03 06:30 AM
Mercman,
You've got a pm...
Pete... 2004 Mercury Marauder 300A Black Clearcoat/Dark Charcoal LEATHER DOB 10/31/2003 DOP 1/2/2004 www.mercurymarauder.net
#711482 08/18/03 02:24 AM
IF anyone is interested, I've posted the pics of the instructions here...
Ford Contours Owners Group CEG Website on MSN
BEWARE 56K Users...
Each pic is 1MB large and there are THREE of them.
If you would rather I Email the pics to you, you can send me a PM
with the email address that you want them emailed to.
Please make sure your ISP will allow an email larger than 3MB.
I do not resend bounced emails.
#711483 09/04/03 03:57 PM
Is this a shift kit, or just a kit that fixes known problems/defects?
1998 Contour GL Zetec I4 w/auto MODS: Fog lights and Mesh grills Soon to come are a set of Rims and Yokohama AVS ES100's Come see at cardomain.com
#711484 09/04/03 09:09 PM
Have you read through the thread ?
Have you looked at the instructions ?
There is more than enough information in this forum to answer this question.
#711485 09/05/03 03:08 AM
my bad I had no time but was interested so I just asked instead of reading on. you could have answered my q instead of complaining about it with the time and energy you spent typing that crap. Thanxz, moderator!!!
#711486 12/15/03 02:32 PM
it costed me $90 to have the shiftkit and sonnax valves installed by a local transmission shop
i took the tranny to them in the back of my dads truck
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
#711487 01/16/04 04:53 PM
One question on this kit that I have. The alumumium rivet that is included, A normal rivet gun won't handle this kind of rivet? Am I correct on this, How do I insert and fasten this rivet?
P.S. Never used a rivet gun before....
Thanks,
Bob
#711488 05/19/04 01:19 AM
You DO NOT need to remove the AC hardware, coolant lines or related hardware-I just did mine-and the only thing I took out was teh battery tray (5) bolts. I didn't even pop off the range selector. I fugure I spent an extra 5 minutes working around teh coolant lines and AC stuff-but-I didn't feel like taking it all off-and the cover and VB will make it out fine. That servo lag bolt trick was good-I will use that-good thinking. I have been taking some pictures and will put up a nice write up when I am done. You probably wouldn't even need to take the battery tray off-but the 5 minutes it takes saved some knuckle skin...
Anyone have the tech info on wear values for the components-what is acceptable?
I am installing the JR kit currently...
~TIM~
Page 3 of 3 1 2 3
