sounds like your car is telling you that the bulb is burned out. easy to check...flick the signal and go back for a look. easy to change...just look inside trunk for couple gromets to remove and the job is done.
if you are in Canada, Canadian tire lists the bulb as part 1157 in error. Take yours out to match it as I can't recall the bulb part.
10 minutes done!
